Today, while running some errands, I noticed that there's a distinct tick going on with the driver's side of the engine. Sometimes, it sounds like an exhaust leak, and other times, it sounds like a lifter tick. Honestly, it sounds more like the former rather than the latter. I do have a set of Remflex header gaskets and a new set of header bolts in case that's what's going on. I'll also change the oil, as I'm still running the oil I put in over the summer when I swapped the engine in.
Other than that, still working on the tune and determining what the truck wants. I've noticed that cold starting, it wants a big shot of fuel, but hot starting, not so much, so I'll have to figure that out. I feel like the tune itself needs more fuel across the board. It is running great overall, save for those few small hiccups. The new (to me) gas pedal has made a world of difference in driveability.
So about that ticking noise...
I popped the hood today to see if maybe a header bolt or two got loose.
Yeah, I'd say that's loose!
In fact, when I touched it, it fell off in my hand! I went around both headers and snugged everything down to see if the noise went away, and it did. About half of the bolts were loose. Sometimes, it really is the easiest thing.
I did pull some logs prior to this, and noticed that in many scenarios, there could be more fuel in the map and there was some strange timing issues off-idle. But after driving it today after tightening the header bolts, it runs noticeably better. I'll have to pull more logs, but I know exhaust leaks can wreak havoc on Sniper/Atomic EFI systems, and that seems to be the case here.
After nearly 4 years of looking, I finally scored a set of better door panels for the truck locally.
As far as I can tell, no one makes reproductions of these. Most of them are like mine: cracked and brittle. When they are in decent shape, they go for a good chunk of change. A guy in a neighboring town posted these up this morning for $30. SNAG!!!
These ones aren't perfect, but they are in serviceable condition. And after a repaint and attaching my wood placards in the panels, they will look great. The armrest pads aren't in the best shape, and neither are the ones in my truck, but I may try wrapping them in marine-grade vinyl or some sort of fabric to spruce them up.
In reply to Tony Sestito :
Nice find on those panels. A little prep work and some SEM Color Coat will have them looking like new.
On the armrest pads, take a look at this YT channel. This guy puts out some incredible upholstery content. Odds are he has something in here that will help you do way better than you thought possible.
https://youtube.com/c/Cechaflo
For what it's worth, I've never stitched anything in my life, and I still find myself watching his videos just for the joy of seeing a master craftsman at work.
In reply to DarkMonohue :
Thanks for the heads-up on that channel! I've always been interested in reupholstering things, but never got around to actually trying. My wife has a nice Singer sewing machine and has taken some courses, so she will also be helping out here. She did a few diner chairs a few years back that came out really great, and those were likely a lot harder to do than some armrests.
Today is Fun Car Friday, so I participated by getting new winter tires mounted for my Forte GT. My nephew did the honors.
On the trip to the shop, I've noticed the ticking getting louder in the engine, and after I got home, I confirmed that the header bolts were all still tight from the other day. So the only other culprit is low oil. Could it be low? Pulled the dipstick, and it was over full. I wanted to do an oil change anyway, so I went ahead with that. And boy, I'm glad I did!
Exactly one quart came out. ONE.
When I installed the engine, there was a mishap with the oil sending unit and A LOT of oil came out. Since I was having issues with the dipstick, I guesstimated that I needed to add maybe a couple quarts. Apparently, my math was off. It did leak a couple other times from various places, but I fixed all that. So all that was left was a single quart!
PRO TIP: Engines run a lot better with a full crankcase. No more ticking and oil pressure is good now.
But that leaves me to the real issue at hand: the stupid dipstick (again). If you recall, I went through the ringer already with the dipstick on this thing. The stock one didn't play nice with the new oil pan and snapped in half, so I ordered a replacement one. I also tried the two LA ones I have, and neither of those are the right length, either (too short). When I pull the new replacement Magnum one, it typically looks like this:
Oil goes WAY up the stick.
Eventually, after inserting it and wiping it about 20 times, I ended up with a closer to actual reading:
Guess it's back to the drawing board with the dipstick. I know there's 5qts in there now, at least. Glad the engine is OK!
Two quick updates:
-After futzing around with the dipstick (again), I've realized that part of the problem is the new dipstick itself. It's really flimsy compared to an OEM one, which is causing it to go in wrong once it hits the pan. It goes in right sometimes, but more often than not, I think it's missing the pan guide and just going wherever. The OEM LA 318 one I have which is a bit too short with the Magnum dipstick tube goes right in. Which got me to thinking, why don't I just swap the LA tube onto the Magnum engine? And of course, while trying to remove it, the thing snapped in half. Because dipsticks are my automotive kryptonite. At this point, either I'll try to get an OEM dipstick or another LA tube and use my old 318 dipstick. Havent decided yet.
-Also, turns out engines with the correct amount of oil in them run a lot better than ones that don't. Who knew? Oil pressure is now about 60psi cold and 40 hot, and no more ticking noises. Feeling good about it, I also took it on the highway today. At about 60mph, the engine turns at about 2600rpm and it cruises right along. It tends to ever so slightly lean pop out the exhaust though, which is odd. I'll have to pull some logs to see what's up. Could be normal since it's got long tubes and exhaust on it.
So, funny thing....
While I did have a hell of a time with getting the dipstick to actually go in the engine, I've been reading it wrong. Most engines I've owned don't care when you check the oil, but I usually check it when it's either idling or after running for a while. Apparently on these Magnum V8's, to get an accurate reading, the engine needs to be ice cold. If you read it at any other time, you'll get oil all the way up the stick, like what was happening to me, due to the crank slinging oil everywhere.
And apparently, this is like Gearhead 101. Somehow I missed this after messing with internal combustion engines for about 32 of my 40 years on this planet. I even asked my dad, and he responded by saying "You don't check it cold? What's wrong with you? I thought I taught you that?".
So yeah, engine is fine, the nut behind the wheel needs the adjustment!
Tony Sestito said:
Somehow I missed this after messing with internal combustion engines for about 32 of my 40 years on this planet. I even asked my dad, and he responded by saying, "Chooch! Wassamattawitchoo? Don'bea stunod!"
I thought translating it into the mother tongue of our shared heritage would foster warm feelings of rememberance. Whatever I can do to help.....
In reply to Jerry From LA :
Yup, my dad has definitely called me a chooch a few times.
In other news, I took the wife out in the truck last weekend (her idea!) to go grab lunch and run errands. She hasn't been in it since I did the seats, and her feet couldn't touch the ground, so I will definitely be lowering it a few inches when I do the floors.
Oh, and we found a pay phone! I decided to call Chrysler Corp and inquire about the paint warranty.
Boo-doo-DOOT!
"We're sorry. The number you have dialed has been disconnected or is no longer in service. If you feel you have reached this recording in error..."
Got a quick update on the truck:
When I dropped the Magnum 360 in, I was shocked that I pretty much didn't have to do any tuning to the existing tune to get it to run. It ran well, but sometimes, it would get funky and stumble or surge. After pulling some logs, I noticed that the places where it would get weird showed that there wasn't nearly enough fuel in that part of the tune. It was running about 14.5-16 for AFR most of the time, which is a bit lean for my liking, and when you asked for more fuel (aka press the gas pedal), it would scramble and stumble until it overcompensated and gave you a big shot to keep it from stalling. I started getting ready to scale the fuel up all over the fuel map when I thought of something:
When I did the initial setup of the truck, I had to plug in what size the engine is. Apparently, it uses the engine size to calculate overall fuel needs, and these needs scale the entire tune, even if you make adjustments. I figured that manual adjustment would take precedence over this parameter, but this is not the case. So, I downloaded and opened up the tune and saw this:
I changed that to 360 CI and immediately the truck ran better. It now hangs around 13.5 AFR and there's plenty of fuel when you need it. It starts easier and cruises better, too. And I didn't have to turn a single wrench!
Today marks 4 years since I brought the truck home, rescuing it from lot plow truck purgatory in central Maine. Reflecting back on that time, the thing has been through a lot! This past year was no exception, from performing an engine swap and picking up some hard-to-find parts that I had been looking for since day one. It's still plugging along, doing Truck Stuff anytime I need it to.
This coming year, I have some more projects planned for the truck. The two big ones are replacing the floor pans and replacing all of the u-joints. I'll also be tackling the interior with new flooring and installing those door panels that I picked up a while back. Looking forward to improving the truck for its 5 year anniversary next year!
