I've been thrashing on George's Cosworth Vega in my spare (ha!) time for a while now and have made a lot of progress. New brake hydraulics and friction stuff, changed all the vital juices, replaced the timing belt and water pump, new KYB shocks and Sumitomo tires, ran down a ground problem causing the gauges not to work. The FI problems tuned out to be a pooped out coolant temp sensor, George located a used one here in town and that's got it running quite well. Still to go: the tach is not reporting for duty, fuel gauge is stuck on full, the fuel tank fill hose has a split and there's a couple of pieces of trim to locate/reinstall. It also needs a bit more open exhaust and some reindexed cam gears to add a bit more snap.
I took it out for a rip this afternoon (don't tell him!) and this little car is a lot of fun. It feels a lot more solid than you'd expect a 32 year old car to feel. Power wise, it's pretty much on a par with other stuff of the era, not as fast as, say, a TR6 or my Jensen Healey but at least a match for an MGB or 510 Datsun. I haven't been able to push it to the edges of adhesion (too many gendarmes in the area!) but it feels pretty composed. This one has Positraction and I still haven't been able to test that thoroughly. At least there's no chattering in turns etc. The steering is a bit numb, but what would you expect from recirc ball steering? It responds quickly to steering input, though. The brakes have finally seated and it stops pretty well. We will probably take it autocrossing on July 13; that should work out any final bugs!
If y'all have forgotten what a Cosworth Vega looks like, here's a refresher:
<img src="" alt="" /> <img src="" alt="" /> <img src="" alt="" />
