So French cleats have popped up in a couple of garage organization threads recently. After watching a few YouTube videos, I figured I’d give it a shot.
I bought a new house fairly recently and I’m still setting up the garage. I moved all of my workbenches and cabinets from my old house, and set them up with lots of peg board, on the single car section of the garage. That is going to be my woodworking and house project section of the shop. The two car side is going to be the auto and metal working side. It’s a blank canvas, so I had to decide what to do for storage. I love peg board, it has worked out great for me for years. But the French cleat system looked interesting, and capable of holding a greater variety of objects. Plus it looks like I can build outwards a bit with French cleats, and fit more tools in the same wall space.
I started off by building the cleats to attach to the wall. I wanted it to look nice but also be cost effective. I’ve seen both plywood and solid wood boards used. I figured boards would be quicker and easier, since I’d only have half the cuts. They had 5 1/2”x8’x3/4” pine boards for cheap, and I ended up with those. Yes, pine is soft, and was a bit of a concern. But the real problem with it was that when ripped in half at a 45, some of the perfectly straight boards twisted as soon as they passed the saw blade. I got enough straight ones to do the wall, but I should have listened to my gut and stuck with plywood. I then painted them white with some leftover exterior paint to blend in with the wall and protect them.
Next I attached them to the wall. I started just above where the workbench will be and worked my way up. It went pretty quickly. Though pine is soft, it appears to be plenty strong enough for anything I could possibly try to hang. It held my weight without trouble.
Okay, that was pretty easy. Quite a bit more work than peg board with all of the cutting and painting, but not too bad. Time to hang tools! This is where it set in that this part would be a lot more work than peg board. I’d have to make everything. I was desperate to hang something, so I grabbed a wrench set and bolted on a cleat.
Okay, not really what this was meant for, but it’s a start.
I’m putting up a second air hose reel on that side of the garage, so I figured I’d move my auto related air tools over. I made this fairly quickly, painting took most of the time. More leftover exterior house paint from the old house. I like the color.
I just laid out the tools I had and added a couple spare slots. I’m going to add another row half way down, behind the top row for little things air tool related. Here it is with a few tools.
I wanted some convenient storage for my supply of auto nuts and bolts. I picked up these bids for $10 from the hammer store. They appear to be the same as more expensive ones elsewhere, I actually picked up another set. Mounted them to a board, painted it, attached a cleat.
So here is where I am now, randomly arranged. I’ve got a lot more ideas in mind. I picked some post style socket holders, that should make a nice project to keep some sockets readily at hand. I’ll update this thread as I add to it, and I welcome ideas. In the end, this is quite a bit more work than other options, but I think it will be worth it in the end.
