1 ... 71 72 73 74 75 ... 85
aircooled
aircooled MegaDork
1/20/22 9:14 p.m.
Here are a few quick shots I got, and a pic of the level of detail in the Tokyo R246 track:
dean1484
1/21/22 6:45 a.m.
cmcmillin31 said:
Hopefully Air can pull the video clip of our 3 wide debacle in the 944.  I was surprised with how close some of the racing was with the radical sr3.
I am hoping he gets the one where two 944 tandem drifted a corner because I think both went in a little to hot and I end up doing an over under on both cars. Efectvly putting us three wide through a corner at speed. That was a really cool moment.
dean1484
1/21/22 6:50 a.m.
R246 looks to be a very well done track!!!
dean1484
1/21/22 2:32 p.m.
So how goes the Brad Mini?  Any updates on that?
I don't mind running any of the cars we ran Wednesday.  Ok, maybe not the Daihatsu, or maybe I need to up my car modding game and see about adding some POWER to the Daihatsu :-)
BradLTL
BradLTL UltraDork
1/21/22 8:02 p.m.
There's no rush on the Mini. The Rev.B version works well for my offline practice.
If you want to run a One Lap series the track list would be:
  1. Nashville Roval
  2. Carolina Motorsports Park
  3. Lanier oval
  4. Barber's Motorsports Park
  5. Hallett
  6. Heartland (Topeka)
  7. Putnam
I think I dropped all of them on the shared drive. They'll need to be tested to ensure they are online friendly.
There's also an autocross at the start, but the mod to run it has been "deprecated", you can see it here:
https://m.youtube.com/watch?v=lMszq585Nhk
aircooled
aircooled MegaDork
1/22/22 12:09 p.m.
Here are shots from the 944 race.  Not exactly what Dean was describing, but some good racing (btw Dean pulled into the pits at the end of the last shot, ending that duel)
dean1484
1/22/22 3:42 p.m.
Ya that was a ton of fun!!!  Ran out of gas with one lap to go.
aircooled
aircooled MegaDork
1/23/22 1:07 p.m.
I think we can start Brad Tour series at any time, we just need to make sure the tracks are good.  Even if the car is not fully updated, we can always update mid-series.  Everyone needs to drive the same car anyway.  We also do need to figure out what the HC steps will be.
So, if we can test the tracks and do some HC testing next week, that would be ideal.
There is probably no point in doing the ovals, unless we want to swap in another known track just to keep the series a bit longer (7 rather than 5).
  • (Nashville Roval)
  • 1-Carolina Motorsports Park
  • (Lanier oval)
  • 2-Barber's Motorsports Park
  • 3-Hallett
  • 4-Heartland (Topeka)
  • 5-Putnam
dean1484
1/23/22 1:44 p.m.
I need a track that people know really well. I then set things up with test weights and see how it changes the lap times. Do we also want to do a negative HC to help those in the back of the field?  This would all but level the field after one race but it would be much harder to keep track of.
dean1484
1/23/22 3:43 p.m.
Pro have you had a chance to mess with the mini?  You were going to make some changes and re pack it separate of the base car. I think you were also going to do something  with capital letters or something .
I will also want a version with a tad more Hp and torque that I am going to want to see about adding a BOP to them to bring them back to the original spec.
ProDarwin
ProDarwin MegaDork
1/23/22 7:04 p.m.
I'll be on tonight to do some updates.
How much more power do you want?  Why add more to then take it away with BOP?
ProDarwin
ProDarwin MegaDork
1/23/22 10:59 p.m.
Brad questions:
What is the swaybar situation like on these?
Can the front be disconnected?  Do you plan on adjusting your setup at all?
Do you run with ABS?
dean1484
1/24/22 12:40 a.m.
There is a new mini that is on the server.  Version 3. Brad if you can try it and see if you can get on the server. Pro corrected some things that we hope fixed that issue. Pro and I had no issues getting in to the server.
Brad can you pass judgment on the tune?  It is locked down with just the basic  things still adjustable. Kind of what we think you would be using at the track on OLOA.  I think Pro really got this to be a really good driving car.
We also tested the HC and I think it will be a HC of around 30.  I will most likely go to a sliding scale on the HC where the jump to a level 2 and 3 HC will be lower amounts of weight added.  I am leaning towards doing a 30-20-15-10 scale. If you get to a HC of 4 you and you win again then you just get another 30 added until you stop winning. laugh
BradLTL
BradLTL UltraDork
1/24/22 8:07 a.m.
In reply to ProDarwin :
I have a stock front and 27mm adjustable rear bar.
I assume the front can be disconnected, I probably won't worry with it.
Yes to the ABS.
dean1484
1/24/22 8:09 a.m.
What about traction control?  Do you have it can it be disabled do you use it?
BradLTL
BradLTL UltraDork
1/24/22 7:37 p.m.
In reply to dean1484 :
Yes it exists, yes I turn it off.
dean1484
1/24/22 9:35 p.m.
So hopefully tomorrow is the last test and tune before the Brad OLOA R53 Mini series.  Looking to make sure the car is usable by everyone and everyone can get in the server.  tomorrow is the last test and tune.
I got a preview of the car last night and it is a really good car.
BradLTL
BradLTL UltraDork
1/24/22 10:02 p.m.
Tomorrow or Wednesday?
dean1484
1/24/22 11:33 p.m.
Wednesday. Worked over the weekend and got my days mixed up.
aircooled
aircooled MegaDork
1/25/22 3:04 p.m.
Are we doing only penalty HC, or do have room to do positive HC?
You could always start everyone at a 2 HC and work from there.  If we do that, maybe out of respect, we let Brad start with no HC.  If he wants he can do the whole series without HC, but as he noted, I don't think the times / techniques will be super useful for actual driving, just the memorization of the track and rhythm.
BradLTL
BradLTL UltraDork
1/25/22 5:35 p.m.
In reply to aircooled :
I don't think the handicap is going to make much difference.  I'm not going to be fast enough to worry about for most of the races.  Like you said, it's about learning the tracks and rhythm.
Also, the Nashville Roval isn't an Oval... it's kinda like a small Daytona. Roval = Road Course + Oval
dean1484
1/26/22 7:18 a.m.
At the moment just an additional weight HC. We need to test that as well as people can pick their color car tonight.
The car the Pro has made is really good. I would be apprehensive to do a weight HC across the board on it. However if Brad said it is to fast I could use the BOP setting to tame it a little and use that as the plus HC performance adder.
dean1484
1/26/22 7:23 a.m.
Air can you look in to livery's?  You could  model brads exact car and there is the obvious Tangerine Torpedo car. If nothing else it would be nice to expand the car color choices.
Edit:  It would not hurt to add GRM logo/banner on the cars (unless our hosts don't want us to) we could do a windshield banner.
Is there a OLOA banner for the cars?  We could run that as well.  Or put the logo you have on the Vids you have made on the front quarter panel. Or a big shield on the hood on a couple cars.  I like the windshield banners. It could be a GRM/OLOA banner.  Or we could just take Monty Python sayings and put them on banners. laugh
One other thing I figured out where the car tune files are saved so you can share actual tunes outside of the in game chat.
dean1484
1/26/22 7:28 a.m.
It has occurred to me that with the collective knowledge people here have about the game we really should put together a "how to" sometime.
dean1484
1/26/22 8:13 a.m.
Actually thinking about the BOP setting that may work well with this car as it acts as a restricter plate hitting the top end much more than the overall performance. On a car like this with a BOP in place you would not have much if any hit pulling out of corners. I bet if you short shifted the car that has a bit of a BOP hit the performance loss would marginal at least until you really started to get in to the BOP range. Probably anything over a 25 percent BOP and there would not be a way to drive around it.  Another interesting thing I learned in the last series was that adding a BOP to the high hp car in small amounts electively gave them a little bit of traction control and in some cases I was faster as I could just hammer the gas coming out of corners with out having any significant wheel spin. The down side to this is if you are getting slip angle out of corners that you are controlling with wheel spin a car that appears to be well balanced will pick up a push when you add BOP and that will become a double performance hit depending on driving style.
U0Fz23NCGTmTA400H5levf51kGmuj9sBXqhf3BEXLeC60Z9ZHT1q9zNrDpcUIIAO
