Tuning our Shelby’s Carburetor
An air-fuel ratio of over 14:1 is certainly not where you want to be for safe driving and maximum efficiency.
With the Texas 1000 rally behind us and the Shelby GT 350’s problems sorted, it was time for a bit more tuning and some corner weighting.
Our initial dyno testing revealed that the engine was running too lean. An air-fuel ratio of over 14:1 is certainly not where you want to be for safe driving and maximum efficiency. We moved from No. 76 jets at all four corners of our carburetor to No. 80 jets on the primaries (front of the carburetor) and No. 81 jets at rear (secondaries) of our carb. This setup turned out to be too rich, so we moved back to No. 78 jets at all four corners.
We then fine-tuned from there by adjusting the idle circuit mixture screws. When driving at highway speeds, a car is still partially using the idle circuit; it’s only turning a couple of thousand rpm.
The Crane ignition system we chose has several preprogrammed settings. These settings combine total timing with how quickly the advance comes in to meet different needs on various engine configurations.
We chose setting No. 7, which was for a high-powered, fairly light car with an aggressive cam. Once we got to the dyno again, we tried different settings. However, this initial choice proved to make the most power and gave the car excellent drivability.
Get updates on our Shelby delivered to your mailbox. Subscribe now for tons of sports car content delivered throughout the year.
Comments
Sponsored by
Ford Racing
Orlando Mustang
National Parts Depot
Jb6E7R6HwG0kEXhRh0XLuJNOfAAIUBRxW5SrlX8V1v5PGLV4io9aUdrvEh0rzQc8
